2in body & 2in suspension lift
#21
Thanks, will the 30", 33" or 275 size tires also raise the height up some? If so by how much? Trying to determine something.
#22
Yes the bigger tires will give you more lift as long as they dont rub
#23
I have 265/75 tires and they rub the frame so you might want to look into some wheels with less backspacing, it will help with rubbing.
#24
Okay i'm really having a hard decision here on finding a comfortable tire for when I do the 2" body lift. So far I have decided to stay with a 15" size wheel (still stock).
If I don't complete the 2" body lift then I've narrowed down to 30x9.50 15
General Grabber AT2 or Cooper Discoverer STT Pro tires.
I've also found out that 30" tires are actually 29.57"
#25
I have the Cooper Discoverer AT3 but if I hadn't got them I would've got the General Grabbers. As for tire size, that actually depends on the tire. Some 30" tires are 29.5" while others are an actual 30". And if you don't put on the other two inches then you'll be happy you have the shorter of the two. It'll cause less rubbing.
#26
I just found a good deal on some General Grabber AT2's 31x10.50 15's. So jack it up another 2"'s and 31 will be fine.
#27
Im running 2" BL with 31" Trail Digger tires, no rub after I "rolled" the fenders lol
