electric fan wiring
electric fan wiring
Ok guys i see a lot of posts with ppl wanting to set up electric fans so after lots of reading heres what i came up with enjoy
http://i1309.photobucket.com/albums/...psepdnhp0j.jpg
If you have functioning A/C, you may want to set it up so that the fans turn on when the A/C compressor clutch engages to improve A/C efficiency at slow speeds. To accomplish this, you will need to wire in another relay.
Other than that note, looks good.
Electric 2-speed fan wiring, ECM controlled
Here is another way of doing it. I used a two-speed Taurus fan.
The the e-fan option needs to be activated in the ECM for full functionality with temp settings of your choice. I used a JET DST #14005. A ground cable also needs to be pulled to pin #9 on the ECM black connector.
This setup works perfectly.
BosseT
BosseT
punx.inc
12-25-2007 12:07 AM
ivannj
02-14-2006 07:10 AM
