wiring electric fan
Old Feb 19, 2010 | 05:57 PM
FreshDA9's Avatar
FreshDA9 is on a distinguished road
Default wiring electric fan
Pulling the heads off the blazer this weekend to fix the head gaskets. i am wanting to get rid of the stock fan and go with some electric units. are you guys just wiring to a constant power that is turned on by ignition key or do you guys have a relay type connection that would work at a certain temperature?
if there is a write up in the DIY section that i missed please direct me. Thank you.
Old Feb 19, 2010 | 06:08 PM
WolfPack's Avatar
You can buy fan controller kits from Summit and places like that. They usually run under $100. They use a thermostat and have an off/on temperature, and if you have dual fans, you can get a dual fan controller that gives you independent control of each fan by temp.
Old Feb 19, 2010 | 06:37 PM
FreshDA9's Avatar
nice information ima have to check out jegs or summits site and find 1. thank you.
toyblazervt
Nov 28, 2010 05:07 PM
toxikchevy
Engine & Internal
Jan 26, 2010 04:27 PM
punx.inc
Dec 25, 2007 12:07 AM
chuckadian
Engine & Internal
Dec 1, 2007 12:00 PM
ivannj
Feb 14, 2006 07:10 AM
