Ignition stays on with key completely out.
Old 07-29-2014, 01:15 AM
S2kylef's Avatar
S2kylef is on a distinguished road
Default Ignition stays on with key completely out.
Here is my problem as abruptly as I can state it. Hopefully someone will be able to point out the issue immediately.
97 blazer 4.3 v6 auto 4x4:
#1 problem - If I hook a charged battery up, the daytime running lights automatically come on, as well as the cluster lights, only a couple of them, as if the key is in the ignition in the turned "on" position ...there isn't a key even in the ignition. I have already replaced the ignition switch, no change at all.
#2 problem - I'm not getting any kind of fuel pump sound, nor can I start the vehicle, unless I spray starting fluid and it'll try but won't stay running.
I've narrowed it down so far to have something wrong with the ignition and fuel system but I'm unsure how to diagnose the problems at hand.
Any help would be greatly appreciated!
Old 07-29-2014, 11:26 PM
S2kylef's Avatar
No input?!! I'm stumped...
Old 08-01-2014, 01:02 PM
abig84's Avatar
crank sensors are common on these trucks for a no start situation but hard to tell without seeing the truck
MetalMan390
01-21-2011 10:27 PM
49er_Dirtbag
01-14-2010 06:43 PM
03BlazerLS
11-26-2009 02:40 PM
jdpilot
11-12-2008 06:01 PM
sidewheeler
02-10-2008 12:11 AM
Quick Reply: Ignition stays on with key completely out.
