Instrument Panel problem???
I've ran out of ideas of what the issue could be, have check every fuse,every wire from the fuse box etc. Anyway the instrument cluster on my 98 Blazer was junk the digital odom/trip meter wouldn't light up for anything also gas needle won't move, today I went and picked one up from a salvage yard for $50 and now the odom/trip meter will work but only one click over with the key. If you turn it anymore or crank it it goes out? Idk what can be causing this. Oh the gas gauge still isn't working. Maybe bad ignition switch??? ECM?? I'm clueless...trip/odom function like they should
blazin4eva
12-17-2009 08:22 AM
trettifire
10-03-2009 08:48 PM
97_blazer
10-14-2007 06:44 PM
New problems: Headlights flicker, instrument panel lights up with buzz and engine quits while cruise
recruiter
01-05-2007 02:58 PM
