off road mods
Old 04-24-2015, 11:28 AM
bruncoon's Avatar
bruncoon is on a distinguished road
Default off road mods
Hey guys I'm starting to make my 03 blazer more off road capable am was wondering you guys had any recommendations On tires, lifts, I've got some welding experience so I want to build my out bumpers and roof racks, but just in general any thing helps thanks!
Old 04-24-2015, 01:05 PM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
If it's going to be an off road only build and you want it to be as capable as possible, I would start looking through some of the solid front axle conversions people have done. There are definitely easier way to lift the truck and get some form of clearance, but a solid front axle is going to be the most capable, in my opinion.
Old 04-24-2015, 01:19 PM
bruncoon's Avatar
Thanks I'm trying to make it just for off road and nothing super intense we don't get a ton of mud where I love just steep rock mountains. And I'm looking at the rc 2.5 inch suspension lift. What would that front axel help my with?
Old 04-24-2015, 01:39 PM
A solid front axle is going to be a lot less prone to breakage. The way these blazers are built uses independent front suspension so you have to deal with joints in each axle shaft as opposed to a single, solid axle shaft for each side. When you start angling those joints beyond the factory angles they tend to break a lot easier, which means no 4WD. But it all depends on how much you're looking to spend, how high you want it, and what you're going to be doing with it.
Old 04-24-2015, 01:57 PM
bruncoon's Avatar
Thanks man that helps whst does that usually go for cost and time wise?
Old 04-24-2015, 02:19 PM
It typically takes a few months to a year of planning and buying parts here and there along with the time it takes to install it. And it will be costly. I've never done one, but from what I've read it can be anywhere from $2000+ after everything is done.
Old 04-24-2015, 02:42 PM
bruncoon's Avatar
No I ment just the axle. But ya I figuerd it will ake about that
Old 04-24-2015, 11:08 PM
The axle itself ranges depending on what axle you get and where you get it from.
c5demon
04-17-2014 12:28 AM
Jimmy_Blazer
Performance & Brainstorming
01-12-2013 08:48 PM
Spectreblazer
03-20-2010 03:36 PM
blazer_in_ky
11-19-2009 10:15 PM
blazerrider101
06-03-2006 08:19 PM
Quick Reply: off road mods
