98 blazer ticking noise/4wd wont engage
Old 02-06-2011, 01:41 AM
maty98blazer's Avatar
maty98blazer is on a distinguished road
Default 98 blazer ticking noise/4wd wont engage
hi i keep hearing a ticking noise its coming from a computer type deal underneath the passenger kick panel, i have called auto parts stores and no one can tell me what it is called but it stops/goes crazy when u hit the breaks can anyone please tell me what is wrong or what that box is called, and my fourwheel drive u push the button to 4 hi and it sometimes flashes but then sometimes it doesnt even light up and wont engage it does that in 4 low also and then sometimes the 2 high light goes off can anyone explain what i need to do to fix that also...Thank you all very much
Old 02-06-2011, 11:43 AM
repomn79's Avatar
repomn79 is on a distinguished road
I'm not so sure on the ticking noise may be some sort of relay or something for your abs or it may just be your abs but as for your 4wd I have a 99 Blazer and I had the same problem, look under your hood there should be a vaccum ball mounted to the hood make sue it's there with the vaccum hose attatched if not find the dangling hose and plug it up with a bolt or a screw. There is also a small vaccum module bolted under a lip by the cowl panel around the center of the truck that should have a vaccum hose running into it make sure that the hose(s) is attatched,1 other thing that you can check and this I would check last because it is under your battery is your front differential actuator you will have to remove your battery and the battery tray to access it but once your there make sure that there are not tears,cracks, or dry rott on the diaphram if so you need to replace it, also check to make sure all of your hoses are ok. Now I did replace my 4WD switch and that did help with the light issue.
Old 02-16-2011, 09:51 AM
Thanks for the information i will check it out and go from there.I got to looking on ebay for modules and came to find out the ticking noise is coming from the transfer case module under the passenger kick panel. by chance would you know if that has something to do with the cruise and the abs also. thank you
Old 02-16-2011, 12:29 PM
blazinloud's Avatar
the tccm is supposed to be on the passenger side (transfer case control module)
Old 02-16-2011, 01:25 PM
Steinbruchsoldat's Avatar
Steinbruchsoldat is on a distinguished road
Same problem like i had. I ended with converting it to manual shift...
xillzxnickx
05-30-2012 02:57 PM
gibson308
09-18-2011 04:36 PM
Hatfield
04-11-2011 10:57 PM
breakyadown89
12-09-2009 06:34 PM
catruck
04-06-2008 12:45 AM
Quick Reply: 98 blazer ticking noise/4wd wont engage
