Axle shaft install help
Old 06-20-2009, 11:34 PM
NVANZEE's Avatar
Exclamation Axle shaft install help
ok today i replaced the inner and outer axle shaft boots. Now i cant get the shaft to go back in. I cant get it past the snap ring. I tried for over an hour trying to force it over the ring but i cant get it. Does anyone have any ideas. If i cant get it do you think it will be ok to drive it without the shaft in for 5mi to work. Then i will have someone at work get it in for me.
Old 06-21-2009, 12:40 AM
mech cb's Avatar
mech cb is on a distinguished road
Got any pics? You say you can't get it past the snap ring, but I would think the snap ring should be off-so pics would help me see what's going on.
Old 06-21-2009, 12:55 AM
NVANZEE's Avatar
the snap ring holds the axle shaft in the differential. There is no way to put it on after since the shaft will be over it. I dont have any pics. I can try to get some tomorrow.
Old 06-21-2009, 03:45 AM
bandidolenny's Avatar
Put it in as far as you can by hand and then put a piece of wood like a 2x4 up to the inner part... then gently tap it in with a hammer. DO NOT drive the truck with no shaft end installed in the wheel hub or you will ruin the unit bearing.
Old 06-21-2009, 08:38 AM
NVANZEE's Avatar
i will try that later tonight but if i cant get it im gonna have to drive it. I dont care if i ruin the bearing since i have a lifetime warranty but hope it doesn't fail before i get there
Old 06-21-2009, 02:16 PM
mech cb's Avatar
I see what you're saying now...Hope you get it figured out.
Old 06-21-2009, 06:37 PM
Yep, use a piece of wood and a good hammer. Tap is not what I have done in the past, but a few good raps with the hammer is all it took squeeze the snap ring into the starting taper on the end of the CV shaft.
Old 06-21-2009, 11:11 PM
NVANZEE's Avatar
oki finally got it. I had a buddy hold it while i hit it a few times with an 8lb sledge. But now my axle nut is striped. So i have to get up early and see if i can get one before work.
Mcg89
03-07-2014 07:35 PM
Qzf74s
15
12-17-2013 02:16 PM
dylan78
04-26-2013 06:08 PM
jmaynard
07-12-2011 01:03 PM
Tony H
09-07-2010 07:45 AM
Quick Reply: Axle shaft install help
