tire size
Old 07-11-2016, 02:42 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default tire size
Hey guys, just wanted some other opinions.
I have an 04 blazer 4 door 4x4 with the stock 235/75/15s on it and its ready for some new tires. Now I'm caught between a couple sizes. First off I might want to put a small lift on it, 2 inches at most with a shackle/tbar crank. I know I could get away with 31s with minor rubbing if any at all. I do know with a tire that big I will loose some performance and mpg though. So like I said I would like some opinions. A few other sizes I'm considering are 30/9.5/15 and 255/75/15. Mainly I wanted something a bit taller to take up the space of the lift, but a bit wider as the snow here can get a bit crazy and I like to ride some trails. Anywho, would just like some thoughts of what I should do.
Thanks!
Old 07-11-2016, 06:29 PM
newguy's Avatar
with my 4 door I needed 2 inch lift and 2 inch body lift to fit 31s. also a wider tire hurts you in the snow. it just plows the snow in front of it
Old 07-13-2016, 12:01 PM
DesertStorm's Avatar
i have a 2" body lift and cranked t-bars and shackles on mine and clear 31's with just a slight rubbing on frame at full crank.
Old 07-14-2016, 10:48 PM
Thanks for the input guys, I have a 95 Jimmy with 4 inches of lift (two body, two suspension) and I have 31s on it on offset rims and they dont rub unless I'm wheeling hard. Good point on the wide tire in snow Newguy. I think I'm just going to go with 30x9.5s and a slight lift. Thanks again
BackwoodsBogger14
Headers, Intake, & Exhaust
10-08-2013 12:20 AM
smitty1244
Tires and Wheels
12-05-2009 01:52 PM
mx_579
Tires and Wheels
09-18-2009 11:36 AM
dshaw1
Tires and Wheels
01-21-2006 02:41 PM
demjjm
Tires and Wheels
10-03-2005 04:44 PM
Quick Reply: tire size
