1984 S-10 Blazer 4x4 5 speed
Old Aug 31, 2009 | 01:48 PM
4x4VegasDan's Avatar
4x4VegasDan is on a distinguished road
Default 1984 S-10 Blazer 4x4 5 speed won't crank
My running lights and dash lights stopped working about 2 weeks ago, turned out to be a blown fuse. The shop replaced the fuse and later that night they stopped working again. I took it back and they cannot find a short. Replaced fuse and they are working fine now. I have had the started rewired the ground for the battery rewired. In dash has had some rewiring done. Anyways, I was on my way to my buddies house and we took a shortcut through the desert. I put it into 4 high and about 50 yards later the truck just shut off. It does not try to crank and i don't have any power to anything besides my headlight/running lights. Ignition switch possibly? I am not very knowledgeable when it comes to the electrical. Also shortly before it shut off the check engine light appeared and then slowly dimmed out. Also before this happened when i would go to start it it would go to roll over and then die out. I would have to give it a little gas before it would start back up. Any input would be greatly appreciated.
Old Aug 31, 2009 | 11:58 PM
abig84's Avatar
everytime i ever seen a truck just shut off and nothing happen the main power wire going to the starter fries. usually on the exhaust manifold. should be easy to check
Old Sep 1, 2009 | 12:00 AM
Thank you. Will check in the morning.
Old Sep 1, 2009 | 03:59 PM
Thumbs down
So it was not the main power wire to the starter. Not very good with eletrical so I just towed it to the shop. See what they have to say...So I guess a branch ****ed one of my fusible links up. Easy fix. $80 dollars for such a simple thing that I didn't see.
Zoidsfan77
Jun 20, 2014 12:25 PM
Cort
Jul 19, 2012 08:58 PM
Duanerudin101
Oct 7, 2011 09:12 PM
Elvis Percy
Jun 10, 2010 01:34 AM
cmh_20
Nov 21, 2009 11:39 AM
