1984 S-10 Blazer 4x4 V8 Swap
Old Jun 20, 2014 | 09:46 AM
Zoidsfan77's Avatar
Zoidsfan77 is on a distinguished road
Default 1984 S-10 Blazer 4x4 V8 Swap
I have an 1984 S-10 Blazer 4x4, with the 2.8 V6 and 700R4 column shifted automatic.
In the next few weeks I plan on swapping in a 350 chevy small block crate motor, but I wanted to get some advice from some people with more experience than myself.
So here is where I need some help. Will my 700R4 transmission bolt up to the small block fine, or do I need to salvage a different bell housing?
Also, my biggest concern in that this kit claims to only work with floor mount automatics, due to drain plug clearance. Is there any way around this, or should I be looking at a different kit. Do you guys recommend a kit that would work out better? It also should be mentioned, that a 5-speed swap is something I would like to do in the future.
Engine:
Chevrolet Performance 10067353 GM Goodwrench 350ci/260HP Engine & Packages - Free Shipping on All Orders @ JEGS
Swap Kit:
Trans Dapt 44061 Hamburger's S10 / V8 ''Engine Swap In a Box'' Kits - Free Shipping on All Orders @ JEGS
Thanks for any advice, let me know if you need any more information.
Old Jun 20, 2014 | 12:25 PM
abig84's Avatar
i dont think the 700r4 was put behind the 2.8. the 2.8 have a different shaped bell housing then the small block chevy so no it wont work.
i ended up just putting a floor mounted hurst shifter in mine when i did the swap, it was a manual so i had no column shifter anyways
gmoneyeagles
Dec 11, 2014 10:53 PM
Duanerudin101
Oct 7, 2011 09:12 PM
Elvis Percy
Jun 10, 2010 01:34 AM
cmh_20
Nov 21, 2009 11:39 AM
4x4VegasDan
Sep 1, 2009 03:59 PM
