1993 s-10 blazer runs like poo
Old Feb 4, 2011 | 04:13 PM
wallace's Avatar
wallace is on a distinguished road
Default 1993 s-10 blazer runs like poo
i have a 93 s-10 4.3 blazer its a problem that started while driving it.it just started missing big time rough idle.has very hard time getting up on rpms runs great at about 4800 to 5000 rpm but any less and it runs bad have replaced plugs wires cap rotor(had to chizzle it off the distributor-RUSTED) fuel filter helped a little..
ck engine light comes on periodicley and the rig runs very rich all the time.. any idea. i was thinking it possibly bad ignition controll module or coil.???? and is the ignition controll module in the distributor
Old Feb 4, 2011 | 05:34 PM
ffox's Avatar
ffox is on a distinguished road
Did you check the code? If it's code 32 it's probably your EGR valve. Some times carbon gets in there and holds the pinion open.
Old Feb 4, 2011 | 05:49 PM
wallace's Avatar
no i havent pulled the codes yet it just started doin this yeterday after i drove it from spokane w.a. to scottsbluff n.e. about 1100 mi but i will and if it is spitting a code 32 than should i clean the egr or just replace it?? also the inside of the dist was extremley rusted thats why i thought of a bad icm.. but thanks for the lead
Old Feb 4, 2011 | 06:20 PM
ffox's Avatar
If it's just a piece of carbon you'll see it, just take it out. I usually clean it the best I can with carb. cleaner, and clean out the port on the motor if there's a lot of build up. I always put a screened gasket on mine, they help a lot..You can get them on Ebay, and some auto parts stores carry them..Never found them with just the blazer gasket tho., they always come in a kit with a Ford AND GM gasket. At least that's all I ever found..
Yeah, the ignition module is in the distributor.
reddheadnla
Apr 23, 2011 11:08 AM
Wexinlo
26
Apr 9, 2011 03:37 AM
zakm0n
Jan 10, 2011 11:42 AM
Scooterewski
Nov 15, 2010 02:39 PM
BrokenBlazr
Mar 3, 2007 11:22 AM
