2.8 to 3.4 Swap Question
Old Mar 26, 2013 | 03:13 PM
Dave884x4's Avatar
Dave884x4 is on a distinguished road
Default 2.8 to 3.4 Swap Question
I just joined this forum hoping to find a little tech help. I have an 88 S10 Blazer 4x4. I am doing a 2.8 to 3.4 swap. I started to assemble the engine the other day and realized the throttle body intake manifold starts to cover what looks like a cam sensor hole on top of the engine. The engine came from a 94-95 camaro, cant remember which year. I removed all of the sensor before it went to the machine shop. My question is 1) since it starts to cover the whole a little can I grind back the intake a little to make it clear and just clip the wires from the old sensor and leave it there or is there a cleaner way to fill that hole? Any ideas would be appreciated, and thank you ahead of time.
Attached Thumbnails 2.8 to 3.4 Swap Question-20d17acc-b21b-4e21-a43c-7c709b0bbadd_zpsf3bbd8d5.jpg
Old Apr 6, 2013 | 06:52 PM
Dave884x4's Avatar
Just in case anyone wants to know, the cam sensor uses a 3/4" freeze plug and the crank sensor uses a 20mm freeze plug.
Old Apr 7, 2013 | 12:15 AM
mike2000's Avatar
mike2000 is on a distinguished road
that freeze plug was probably the best way to go better than grinding on the intake i hope you have better luck out of that 3.4 than i did in my bird
Old Apr 7, 2013 | 07:17 AM
Dave884x4's Avatar
I hope it works out well. This thing is built far better than what comes from the factory. Everything has been replaced. The only thing that is going to be reused is the intake I had bored out and the throttle body. I just hope my comp cams rockers fit under the Fiero valve covers without a problem.
Spectreblazer
14
Jan 31, 2010 01:14 PM
D1LLeX
Performance & Brainstorming
Feb 21, 2008 04:49 PM
wesmagyar
Feb 16, 2008 12:19 PM
mudd
Engine & Internal
Jan 28, 2008 02:50 PM
mortalum620
Engine & Internal
Aug 17, 2006 01:24 AM
