4.3L white smoke
Old Sep 11, 2008 | 07:51 PM
Sparky's Avatar
Sparky is an unknown quantity at this point
Default 4.3L white smoke
Hello, my 92 4.3L has been weeping coolant out the right front of the intake for a while. I have heard of this problem a lot. I put a little leak stop in the radiator a while back. Now the engine is putting out white wet smoke (fog) out the tailpipe. My question, before I tear into it is, am I looking at replacing just the intake gaskets or will I have to replace the head gaskets too. I keep filling the radiator and it keeps going down. I can not find any leaks.
Thanks
Doug
Old Sep 11, 2008 | 10:41 PM
94blueknight's Avatar
94blueknight is on a distinguished road
Default RE: 4.3L white smoke
i'm guessing u have around 100K mi on it? ya def sounds like an intake gasket. its not to bad just time consuming. i did mine at 110K mi and has been good since. it took me 2 nights of about 5 hrs or so each night to get it all fixed.
Old Sep 12, 2008 | 06:35 AM
I would bet that it is just a head gasket problem. You could run a compression check to make sure.
One thing is for sure. If you are getting coolant into the combustion chamber, chances are it is getting into the oil as well. I would not drive it at all until you get things figured out and fixed!
Old Oct 4, 2008 | 07:16 PM
Sparky's Avatar
Well, removed heads and gaskets looked fine. No. 8 cyl. looked dark around the valve area. Spark plug fouled with black gunk. No water in oil. Did find some external leaks at aluminum heater hose connector and intake gaskets. Aluminum hose connector snapped off in intake when touched (no suprise). Will clean up heads and check for cracks, then re-seat valves.
92blazer92
Jan 25, 2010 12:46 AM
Zonablazer
Oct 14, 2009 07:16 PM
vernoninmd
Feb 24, 2008 11:52 AM
apoch
Feb 13, 2008 11:47 AM
SniperX13
Jun 11, 2006 03:00 AM
