4x4 problem any ideas
Old Mar 30, 2011 | 02:29 AM
bowtiemode@yahoo.com's Avatar
bowtiemode@yahoo.com is on a distinguished road
Default 4x4 problem any ideas
1988 s10 blazer 2.8, cant figure out why it wont lock in 4wd. I can put it in 4 high (still wont lock in) and it wont even let me put it in neutrl or 4 low?? please help thanks
Old Mar 30, 2011 | 06:26 AM
There is a ton of information out there for you to read through. 4wd problems are well documented. I would start in the Tech Article (DIY) section, specifically THIS THREAD. From there, the index has a lot more topics to read through and using some of the specific terminology from the threads you find in the Tech Article section, you can do some very effective searching.
Good luck with your problem and let us know if you have specific questions not covered already in other posts.
Old Mar 30, 2011 | 12:33 PM
auto-bot's Avatar
auto-bot is on a distinguished road
That happened to me once, on the trail. Got it back to the garage and discovred the 4X4 vacuum hose was disconnected (in an '86, tho). You have probably already checked this part, but it was a pretty quick fix that day which was easy to overlook when I was freaked out about not having 4WD.
Old Mar 30, 2011 | 05:24 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Sounds like a couple of different problems. Vacuum switch or hoses(no lock) and your T-case may be out of rig. You might have something interferring with the linkage. Gotta get under it and have a look.
Old Mar 30, 2011 | 06:16 PM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
All great ideas. Searching is your best bet. For any extra info on the vacuum check the link in my signature on my post here about the vacuum. Also, you must be in neutral and stopped, with the middle button fully depressed in order to get the shifter to go past n or into 4lo on the transfer case. It also says this in the manual if your soo lucky to have one.
Old Apr 1, 2011 | 02:43 AM
keithaz24's Avatar
keithaz24 is on a distinguished road
I agree with the vacumm switch issue. I pulled my transfer case to reseal it and when I reinstalled it in hooked up the vacuum line wrong ( no 4wheel drive) unplugged it and plugged it in correctly and everything worked fine.
Old Apr 1, 2011 | 01:16 PM
These lines are 2 different sizes
Old Apr 2, 2011 | 09:36 PM
keithaz24's Avatar
mine must be different. i have a plug with three lines in a triangle shaped plug that plugs in on the driver side top of the transfer case.
alamantia
Headers, Intake, & Exhaust
Jan 21, 2010 05:20 PM
bjsx8f
Oct 26, 2009 11:29 AM
kdanderson5
25
Nov 13, 2008 03:16 PM
gizwilly
Sep 5, 2007 11:08 AM
hicksjw
Jan 10, 2007 04:32 PM
