87 s10 blazer prob
ok so i bought a blazer with 2putt8 in it ran good then i took the truck off the trailer and it sat for a few weeks went to start it and it cranked over strong would not fire. i noticed i did not hear fuel pump so i went to change it, tested it it was good, then checked fuses found ecmb fuse was dead changed it to only have it pop. found that problem at the oil presure switch wires.
now i have no pump when i turn the key but works when i put 12v to it. changed relay looked for fuses but no luck.
what could it be????
any help would be great
thanks
thanks
what is 2putt8? Recheck your oil pressure switch wires and fuel pump relay. I'm not sure how similar your 87 is to my 93. Let me do some research, and I'll get back to you.
checked realay seems to work not sure on how to bypass switch would like to do that
Fix the problem at the "oil switch" wires.
![Icon Bricks](https://blazerforum.com/forum/images/smilies/icon_bricks.gif)
thanks
thanks
thanx
LSpoweredStepside
09-30-2013 09:22 PM
kashmoney07
11-28-2009 04:49 PM
muleman
05-26-2008 01:11 PM
gsdmix
03-15-2008 06:06 PM
heitger0003
04-17-2007 03:33 PM
