91 Blazer-no idle, dies, then starts up
Old Jul 20, 2009 | 10:12 PM
TTATE's Avatar
TTATE is on a distinguished road
Default 91 Blazer-no idle, dies, then starts up
Got a 91 blazer (205,000 miles) that sometimes will die out at idle. Let it sit and then starts right up and runs fine (intermittent). I replaced the tank, fuel tree on top of the tank, fuel filter and fuel pump about a year ago. Codes were reading bad oxygen sensor and map sensor. Replaced both and currently no codes show up on the code scanner. Any help would be appreciated.
Old Jul 20, 2009 | 10:34 PM
TTATE's Avatar
Default 91 blazer idle prob
I also replaced wires, spark plugs, rotor and distr. cap recently.
Thanks
Old Jul 21, 2009 | 11:09 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
What brand of plugs, wires, cap & rotor did you use?
Old Jul 21, 2009 | 03:11 PM
TTATE's Avatar
Bought from autozone...do not recall brand and not able to check for a couple days.
Old Jul 21, 2009 | 03:16 PM
These trucks are really picky...replace 'em with AC Delco. For the wires, Autolite Professional seem to be good, but get Delco for everything else.
Old Jul 21, 2009 | 05:43 PM
TTATE's Avatar
I hear ya but when it runs...it's not missing or sputtering...just intermittantly dies, especially at idle. No expert here but seems like it would run crappy all the time if the plugs, wires were the problem.
Old Jul 27, 2009 | 11:33 PM
rdhack's Avatar
rdhack is an unknown quantity at this point
Idle Air Control Valve.
Old Aug 11, 2009 | 07:43 PM
TTATER's Avatar
TTATER is on a distinguished road
Default Update
Replaced Idle Air Control Valve, Ignition Coil, fuel pressure regular, fuel pump, and fuel injector relay. Still same problem. Local mechanic figured it out and it was the electronic spark control module.
rustyiron
Apr 21, 2012 11:28 AM
reddheadnla
Apr 23, 2011 11:08 AM
sk8_dude90
Nov 30, 2010 02:25 AM
Blazer Will
Dec 13, 2009 06:22 PM
redneckwoman
Sep 3, 2009 12:04 PM
