93 fuel system issues (hellpppp)
Old Mar 17, 2011 | 02:12 PM
walnut4's Avatar
walnut4 is on a distinguished road
Default 93 fuel system issues (hellpppp)
Ok, i bought this 93 blazer with a 4.3 vortec. drove it a couple weeks.had some issues with reverse( think i have that resolved). found broken motor mount on drivers side. the thing is, i parked it, the next morning it wouldnt start so i began the process of elimination. fuel pump wast working.found a melted wire in the tank (ground wire to fuel pump). replaced wire harness. figured it was the relay so i took the air relay and pluged it into the fuel relay plug. cool the motor started. now it idles really roughly. i am stumpped now....it had a little skip before all this but not much of one at all not it is almost like it is missing a plug (already replaced wires and plugs).no i didnt cross them, did it 1 at a time.yes all the wires are connected properly.no the fuel filter isnt clogged (checked that as well).and fineally at the back of the motor near the distributor is a vacume junction which im sure isnt done properly as i dont have a vacume diagram however it is at the best combination for the motor to run. can anyone give me some insight on this?
Old Mar 18, 2011 | 08:44 AM
walnut4's Avatar
well the saga continues!! not it is leaking fuel from the #6 cylinder.......... does this thing need me to take my shotgun to it and end this sillyness?????????????????????????????????
Old Mar 19, 2011 | 04:43 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Use the search option many , many , other people have had this problem to .
Old Mar 20, 2011 | 01:55 AM
Cidium's Avatar
Cidium is on a distinguished road
First, I would spend the money and buy yourself a fuel pressure gauge and check the system pressure and leak down. Did you notice anything about the plugs when you changed them, fouled/lean?
Old Mar 20, 2011 | 06:58 AM
walnut4's Avatar
when i changed them they were ok,
Old Mar 20, 2011 | 09:57 AM
ohsofly's Avatar
Number 6 huh? Thats right below your FPR... Methinks that fuel pressure tester would be a good investment.
Old Mar 20, 2011 | 08:17 PM
danaandmeegz's Avatar
danaandmeegz is on a distinguished road
I did the same thing on my 4.3l. new fuel pump and sending unit because of the bad looking wires. After I was done it still wouldn't start. I guess those wires were still ok, but I couldn't believe it by the looks of them. That's when I did massive searching in this site to find that the fuel pressure gauge is a must have with this engine. I should have been issued by GM when it was purchased. I found my problem was an open fuel injector coil (in the body of the injector spider body). I found this with a meter, and it wasn't the wiring or connections (rare find I have gathered, but not impossible). I found a used spider from a pull-a-part for less that $10.00. So anyways, when I pulled the plenum off I saw where the fuel pressure regulator had been leaking too. So replacing the nut-kit, the used spider body, a new gasket and installing a new FPR (it was leaking on the one from pull-a-part too) and the engine hasn't ran this good for years.
alingerj
Sep 12, 2011 09:08 PM
liltittle62
Dec 26, 2010 03:55 PM
sparky672
Oct 11, 2010 09:42 PM
mcatnova
Oct 7, 2010 09:08 AM
azari215
Feb 12, 2009 09:31 PM
