94 4.3 W throwing codes 22,34,42
Old 12-12-2011, 08:46 AM
workshop4ever's Avatar
workshop4ever is an unknown quantity at this point
I try to avoid using old seals/gaskets but only because they are typically a cheap part to replace while you are already in there. It is certainly possible to re-use an old seal, but if it breaks while you're trying to fix this then you'll have to run out and find one. If you can... Always better to have the tiny parts like that on hand, just in case IMO.
Is it possible the autozone one does come with a gasket? or you have opened the box and seen there is no gasket (autozone parts are funny like that sometimes)
According to the pictures I can find on rockauto, one of the SAP parts comes with what looks like it may be the seal you are referring to. It appears on the vin W part number, but not the vin Z part number:
More Information for STANDARD MOTOR PRODUCTS AS17 (Vin W CPI)
More Information for STANDARD MOTOR PRODUCTS AS165 (Vin Z TBI)
Last edited by swartlkk; 12-12-2011 at 08:59 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old 12-16-2011, 12:27 AM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
I am still not sure about this since autozone's web site as well as napa's site shows a picture of a map sensor that is identical to this MAP SENSOR CHEVROLET BUICK ISUZU PONTIAC GMC 5.7 3.1 | eBay and looks exactly like the sensor picture for engine W posted above minus the seal. Are all of these sensors the same minus the gasket or are they actually different? I am considering playing it safe and going with the advanced auto sensor for $50 but I am trying to save money since I am now paying way to much for rent.
Old 12-16-2011, 02:57 AM
I would lean towards the one that comes with a seal, as it is more likely to be the correct part and is more likely to contain all the parts you need. I would agree, just play it safe with the advanced auto part.
dlippiet
10-07-2010 10:36 PM
Eff10
Headers, Intake, & Exhaust
09-24-2009 12:47 PM
OILCOUNTRY
02-22-2009 11:27 PM
manalive
12-10-2006 01:41 PM
Lucky614
03-29-2006 03:03 PM
Quick Reply: 94 4.3 W throwing codes 22,34,42
