94 blazer, 4.3 vin w, a few little problems.
Old Jun 5, 2010 | 06:31 AM
joshua_andrew92's Avatar
joshua_andrew92 is on a distinguished road
Default 94 blazer, 4.3 vin w, a few little problems.
engine has 213k miles on it.. this may be why im going through these troubles right now.
I recently changed the oxygen sensor about a week ago, and it still smells really rich coming out of the exhaust. its almost bad enough to where no one wants to stand behind the truck because of the gasoline smell. is there anything else i can do to make the smell go away?
My engine makes a tapping sound, i have had it checked out and someone said they think it is a lifter going bad. it's not a very loud tap and it only happens when the truck is idling.
Sometimes, when i come out of four wheel drive, it takes a while for it to register, even though the shifter is in 2 wheel, the front wheels are still lit up saying its still in 4 high. Anything to do about this?
Thank you very much for your time, any and all help will be greatly appreciated!
Old Jun 5, 2010 | 07:40 AM
ohsofly's Avatar
Do you get any Engine codes to share? Gas milage worse?
Old Jun 5, 2010 | 06:05 PM
gas mileage has been going down steadily but i think that's normal. i went from getting about 375 miles per tank to around 250-275 per tank now... i don't get any codes because the service engine light never comes on. it comes on periodically but usually shuts off.
Old Jun 10, 2010 | 09:59 AM
rusty91's Avatar
rusty91 is an unknown quantity at this point
it sounds like your central injector is going bad or 1 of the fuel lines in the intake is leaking if there is gas in the oil that is usually the problem
Old Jun 13, 2010 | 01:33 AM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
mine use to do that but went away
Old Jun 17, 2010 | 10:53 AM
I don't have gas in the oil. Just changed it recently and it smells just fine, doesn't smell burnt or gassy or anything. Just like used oil.
93S10TahoeLT
Apr 5, 2013 06:59 PM
altoncustomtech
Feb 27, 2011 09:48 AM
gojo83
Jan 19, 2010 01:40 AM
SlydinClyde
Oct 18, 2009 08:14 PM
BlazerSS
Engine & Internal
Apr 21, 2007 03:44 PM
