94 Blazer False MAP sensor code
Old Aug 21, 2019 | 08:53 PM
Barns's Avatar
Barns is on a distinguished road
Default 94 Blazer False MAP sensor code
Ive changed the MAP Sensor twice thinking the first one was faulty. Still got the code. I use to have an O2 code but got rid of that to get the MAP sensor code. Ibe replaced: spark plugs, plug wire's, changed bad vaccum hoses, distributor and cap, fuel pump with filter, inline fuel filter, and the coolent temperature sensor. Its still having a hard time starting and accelerateing. I NEED HELP.
Old Aug 21, 2019 | 09:50 PM
GeorgeLG's Avatar
What are the specific codes that you are getting?
What problems are you having?
George
Old Aug 21, 2019 | 10:30 PM
Barns's Avatar
It's a 33 and a 35. The 35 is because I increased the idol do it doesn't die.
Old Aug 22, 2019 | 12:04 AM
You are new so you likely didn't realize that you have inadvertently hijacked a very old thread. It is better to start you own so that any help you get is kept to your issue only.
Old Aug 22, 2019 | 06:05 AM
**Moved the most recent posts to a new thread in the 1st gen tech section**
The 'Report Post' () feature can be used to send a notice to the staff for further action on posts such as this even though it doesn't specifically call this out in the note at the bottom of the page that opens.
Little Roober
Nov 25, 2012 09:12 PM
rlbates60
Oct 7, 2010 05:56 PM
thehustler211
Mar 13, 2009 01:49 AM
88hurstolds
Feb 26, 2009 09:41 PM
ggwash21
Aug 8, 2007 08:58 PM
