94 S10 Blazer Started by Reversing Firing Order
Old Jul 16, 2021 | 11:05 PM
ArnoldsMind's Avatar
ArnoldsMind is on a distinguished road
Default 94 S10 Blazer Started by Reversing Firing Order
Originally had a Crank No Start situation with my car after removing Spark plugs to change the Distro cap. Initially tried the factory firing order, but it did not work. I confirmed Fuel Pressure, and spark. But the engine wouldnt fire. I changed The Distro Cap, Rotor, Coil, and ICM. Nothing worked until I put Cylinder 1 in the 3 position on the Distributor Cap and worker with the 1-6-5-4-3-2 firing order from there. It was something I tried out of desperation.ation with my car after removing Spark plugs. Initially tried the factory firi
https://youtu.be/gpORXGQnsJAng order, but it did not work. I confirmed Fuel Pressure, and spark. But the engine wouldnt fire. I changed The Distro Cap, Rotor, Coil, and ICM. Nothing worked until I put Cylinder 1 in the 3 position on the Distributor Cap and worker with the 1-6-5-4-3-2 fir
Old Jul 21, 2021 | 01:03 AM
1-6-5-4-3-2 is the standard (factory) firing order for the 4.3 V6
Old Jul 21, 2021 | 09:07 AM
I'm referring to the placement of the wire that goes to cylinder 1 on the Distro cap. It didn't start with that wire in the designated spot for Cylinder 1. I had to start the firing order in the spot for Cylinder 4 and then Cylinder 3 through trial and error.
Old Jul 22, 2021 | 05:53 AM
got it - glad you got that fixed.
JavierEscalonJr
Oct 14, 2020 11:38 PM
danp95
Feb 3, 2013 06:27 AM
ccrage2005@aol.com
May 12, 2011 03:44 PM
jonny22107
May 11, 2010 02:04 PM
blk97blazer
Engine & Internal
May 1, 2006 04:30 PM
