94 wont stay running
94 4.3 s10 blazer wotn stay running, i just replaced feul filter, plugs wires dist. and cap, idles fine but when i put it in gear it just dies, really making me mad, any help would be awsome
s-10 wont run right ? idle stalls in gear?
Just to let you know your are not the only one having the same problem I am having the same exact issues and 3 mechanics later still no fix I am getting tired of working on it and really can't spend to much more on it !! I'm all out of ideas myself and dont know what to do next so if you find the prob please post it or let me know thanks.
To the OP, have you checked the EGR valve? Traced vacuum lines for possible leaks? Checked the fuel pressure at the engine?
i talked to a mechanic he said its probly tghe egr..if not it could be the torque converter, i havnt gotten around to the egr yet but ill let you know when i fidn out
I have already checked and cleaned the egr even cut out a pop can to the size and blocked it and put just a pin hole in it didn't change anything.and the torque conv isnt locking up but today I got another mech to pick it up and hope fully he can find the prob
I have did the rebuild for the tbi it self checked all vac lines several times I did want the fuel pressure checked but the one mec said it didnt need it, its getting gas and its a new fuel pump and sending unit but ive been told the can go bad easily or not a top of the shelf brand,s-10 are picky to that I guess?
ive redone the egr ,,it seems to be that t runs fine until it reaches 210 degrees normal running temp,,that it starts to surge and idle all crazy,,some times it does soemtimes it doesnt,,it will be fine in park or nuetral but when put in other gears it wants to die and the lgiths dim, but sometimes its fine,,today i put it in 4 lo and it stalled,,but 10 minutes later it was fine to do a burnout lol..any help please,i need to get my baby running right again my pops wont let me use his jeep any more cuz i brought it home covered in mud lol, thanks
that is an indication that it is a sensor problem of some sort. Are there any codes stored? Have you replaced the O2 sensor?
a few weeks before it started happening i went to the junk yard and got a whole new y-pipe and i used my old sensor off my old y-pipe,,idk about the codes,,sometimes the check eng is on and sometimes its off,,its frustrating
tatkinson1981
06-09-2009 09:00 PM
millertimee
03-24-2008 01:32 PM
codereddanger84
11-13-2005 02:52 PM
