AC Hardly Blowing
Old 06-26-2018 | 11:36 PM
LegalCT's Avatar
LegalCT is on a distinguished road
Default AC Hardly Blowing
I’ve got an 86 (I think) S-10 Blazer (2.8 V6) and the AC in it hardly blows at all. Even on high you can’t feel it unless you have your hand right next to the vent. Just curious what are the things I should be trying/checking to work this out. Living in Texas I like my AC lol. One thing I’ve seen is to check wether or not the fan modes do anything, and mine has low - high modes working, so I don’t believe that switch is the issue.
Old 06-27-2018 | 05:30 PM
Rusty Nuts's Avatar
Welcome to the forum. An incorrect amount of refrigerant in the A/C can cause the moisture to freeze and block the air from going through the evaporator. The fan will work fine on vent and heat but not on A/C. No water runs out the A/C drain because the cold radiator is frozen over like a bachelor's freezer.
Old 07-01-2018 | 09:12 PM
christine_208 will become famous soon enoughchristine_208 will become famous soon enough
Is it the airflow that is not sufficient? Do you get good air flow when on heat? Check to see if the evaporator is blocked with debris. Mine was packed with tamarack needles and itsy-bitsy ash leaves.
Kurtan
06-04-2018 08:05 PM
elwaykid
07-28-2014 01:51 PM
dannycam
07-09-2009 07:58 PM
tcjacobs
04-08-2008 01:03 AM
erik102207
11-19-2007 10:31 PM
