Another heat/AC blower issue.
Old May 29, 2011 | 04:10 PM
Jmooney152's Avatar
Jmooney152 is on a distinguished road
Default Another heat/AC blower issue.
94 S-10 Blazer 4.3W Tahoe LT
Blower was working on low only, no matter what the switch position was. Then it went out completely.
I have since changed the resistor, relay, switch, blower motor, fuse and checked all grounds. still nothing.
Im hoping you guys might have an idea that doesnt require me to rewire this, Its looking like this is my only other option.
If any of you guys have a PDF wiring diagram, that would be handy.
Thanks in advance.
Old May 30, 2011 | 02:35 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Do you have power to the terminal block on the firewall? There should be a hot wire from the battery going directly to that. Check and make sure you have power there first. I believe that connection supplies power to the blower motor.
Old May 30, 2011 | 06:52 AM
Jmooney152's Avatar
I think I know what youre talking about, Im gonna go give that a look.
Old Jun 11, 2011 | 06:07 AM
Jmooney152's Avatar
Ive went through the wiring. Ive got voltage into and out of the relay. The wiring diagram shows a fusable link but, I cant find it. I disconnected the pigtail connector and found the plastic around one of the "pins" melted. I can buy the female side of the pigtail new, not the male side, which is where the damage is. Off to the junkyard I go.
Once I replace both sides of that connector, Then I gotta get to work figuring out what caused that in the first place.
Any ideas where this fusable link might be located. It would save alot of time pulling off tape and shielding material If I knew where to start.
Old Jun 11, 2011 | 08:40 AM
Jmooney152's Avatar
Found the problem to be a broken connector on the switch itself. When I would remount the heater control assembly in the dash, the connector would lose contact. It wasnt coming completely off, just enough to create a short. Sometimes its the simplest things.
maxvamp
Oct 31, 2020 08:19 AM
paxlineman
13
Jan 30, 2010 09:25 PM
Rhodes19
Nov 23, 2009 02:01 PM
ckirv
Nov 28, 2007 10:15 AM
TruckeeT2
Feb 3, 2006 01:07 AM
