Bad shaking when I hit the gas
Old Feb 17, 2006 | 10:45 AM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Default Bad shaking when I hit the gas
I have this problem that just showed up all of the sudden.
For those of you that don't know my truck, it's a '93 s10 4x4 6cly auto.
I drove to and from work on Tuesday with no problems. I came home for about 15 minutes, went to get my plate sticker renewed and then went home. I cooked dinner, then started up my truck to bring my girlfriend dinner at work. As soon as I started up, I noticed something off. When I accelerated, there was a terrible shaking, and it took a long time pick up speed. I had come home on a road that has these speed humps, so maybe something got bounced around when I went over one?
It is not as bad when the truck is warmer, but there is still an obvious issue. It only happens when I hit the gas and it is there slightly at idle. When I coast it is not there at all.
Some history: I just replaced my resignator pipe and fuel filter last week. I still haven't replaced my engine manifolds ($), so they have some cracks in them. There are no check engine lights coming on at all, which makes me think it is NOT a sensor issue. However, it has been cold outside, so maybe because of the cracks in the manifolds, the cold air could be screwing up the sensors. I haven't driven the truck since. I have started it up once since Tuesday and it was still shaky on idle. I haven't tried to get any codes since there isn't a light coming on anyway, so it probably wouldn't have one anyway.
This is what I think COULD be wrong:
Like I said above, maybe some sensor going all squirrelly because of the cold air.
Throttle body might need a good cleaning. I haven't checked it yet because it's been either cold as hell or freezing rain outside.
I DON'T think it is fuel related, and I certainly don't think it has anything to do with the fuel filter being replaced.
Any input or something I might be missing?
Old Feb 17, 2006 | 12:22 PM
Jman's Avatar
Jman is an unknown quantity at this point
Default RE: Bad shaking when I hit the gas
Sounds like a timing issue to me, but who knows.
I would ckeck your wires to make sure you didn't melt one to the manifold, and check for heat cracks. also check that they are all tight at the cap and plugs.
All that I can think of at the moment.
Good luck
Wait till its warmer outside though, its freakin freezin here and all roads are closed up again.
Old Feb 17, 2006 | 03:11 PM
lovetheblazer's Avatar
lovetheblazer is an unknown quantity at this point
Something similar happened to me once...
Removed and cleaned the throttle body with carb cleaner...cleaned the MAF with electrical cleaner and the truck felt like a champ again...
Old Feb 17, 2006 | 04:19 PM
m00nwater's Avatar
I nevr thought of it maybe be a timing issue. I'll check that out as well.
I hope all it takes is a good cleaning on the throttle body. I've got some at home, so I'll try and do it as soon as it gets warmer out.
Old Feb 17, 2006 | 08:57 PM
m00nwater's Avatar
Well, I took it out for a quick drive today to try and maybe get some insight. I think it is for sure related to the exhaust manifolds. Could be be that the hole has gotten so big that it would cause such a large shake?
Old Feb 18, 2006 | 12:04 AM
4lowlife's Avatar
I think it is shivering cause its so cold out.
navarro913
Sep 1, 2010 10:27 PM
cavscout_blazer
Apr 4, 2010 12:08 AM
GimmieBoost
Oct 9, 2008 06:15 PM
huskers95
Oct 7, 2006 02:39 AM
djbass_mekanik
Suspension Tech
Jun 26, 2006 03:25 AM
