Blazer problem
Old Mar 26, 2011 | 11:35 PM
ramrod83's Avatar
ramrod83 is on a distinguished road
Default Blazer problem
i have a 94 chevy blazer s-10 4x4.It sometimes will die and start up a few minutes later.I have replaced the control moduele and all other tune up parts.It has a leak in the radiator.Does this have a shut off senser or something when it gets hot or low?
Old Mar 27, 2011 | 09:05 AM
ely0569's Avatar
ely0569 is on a distinguished road
I don't believe it does.....
Old Mar 27, 2011 | 10:05 AM
ramrod83's Avatar
Default blazer problems
Anybody know what it could be?I have also replaced the fuel filter and did a fuel pressure test and got 55 to 60 psi.What else could cause this
Old Mar 27, 2011 | 11:38 AM
ely0569's Avatar
I had a car that shut down everytime it got hot and started back up a few later and it was the crank sensor, though I don't know if that would be your problem.
Old Mar 27, 2011 | 12:06 PM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
Could be you temp sensor, your not throwing any codes? The spider injector can cause weird things like this to happen as well.
Old Mar 27, 2011 | 03:33 PM
ramrod83's Avatar
I pulled got codes and got none
Old Mar 27, 2011 | 10:39 PM
ohsofly's Avatar
You may want to check out that connector on the fuel injector. Get her running, open the hood, and then down under the throttle body there is 2 wires that go into the intake through a rubber gromet - grab those and give them a tug and push and see if you can stall it out. They are blue and red. If you do make it stall, which I suspect it will, then you will need to buy a new injector harness for about 8 dollars and a plenum gasket for about 20 and crack the topend open and cut off and solder on the new harness. Its an easy job. The harness has a rubber thingy in it that degrades from the petroleum vapors over years so it then makes a crappy connection to the injector unit. The new one is made of silicone or something that will hold up better for time.
Old Mar 29, 2011 | 03:11 PM
ramrod83's Avatar
i will try that as soon as i get it back from pepboys.They told me it was the spider injector.700 dollars later not even 5 miles from the shop it dies again.Now they are trying to tell me it has carbon in the intake and is clogging the egr.that does not make sense.the truck starts and runs fine.when it stalls it doesnt chug or nothin it just shuts off.then starts back up aminute later. does this sound right?
Old May 31, 2011 | 05:00 PM
clifford0481's Avatar
clifford0481 is on a distinguished road
i just ran into the same thing... figured anything out yet?
hotrodsbyg
Aug 15, 2011 11:47 AM
96realwe
Dec 10, 2010 09:19 AM
English5
Jul 16, 2010 11:11 AM
Confuused69
Aug 2, 2009 11:53 PM
Daytripper540
Mar 29, 2007 03:54 PM
