Blazer wont start...please help
Old Mar 13, 2007 | 10:29 PM
scottyk's Avatar
scottyk is an unknown quantity at this point
Default Blazer wont start...please help
please help..engine cranks but wont fire..
replaced-
plugs
wires
rotor
dis. cap
(engine is getting fuel)
I think its a minor problem..I got it to start up once and heard a whinding(rubbing) sound from the distributor
(All plugs and hoses hoses are clean, and secure)
Can someone please help????????
Old Mar 13, 2007 | 11:10 PM
Default RE: Blazer wont start...please help
I have directed your other post to this one.
battery connection question
Old Mar 14, 2007 | 08:33 AM
scottyk's Avatar
One thing I have left to try is the thick gauge ground wire off the battery, that connects into the bottom of the engine is pulled out a little bit ( but feels firm)
If this is the problem of why the Blazer wont start, then a jump-start should fire it right up, right?
Cuz it doesnt
Old Mar 14, 2007 | 09:38 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Have you checked for spark? What is your fuel pressure? Also what make, model, year?
Old Mar 14, 2007 | 09:54 PM
scottyk's Avatar
93 s-10 blazer
yes I checked for spark in the #1 plug and got it..
Not exactly what the pressure is, but fuel squirts out pretty fierce when I push the pin..
The ground wire going from the battery to the engine looks pulled out a bit. (still need to fix)
Could this be the reason it will crank but not fire or it would not crank at all?
Also when I did get it to start while changing th plugsit made a steady whinding/rubbing sound(almost like an electric alarm clock), coming from the distributor...then it died..if this might help diagnosing
zblazerz
Apr 8, 2015 12:22 AM
welderman85
Jan 10, 2014 10:06 PM
bommaritomike
Nov 19, 2010 06:56 PM
birdmomma
May 10, 2010 03:03 PM
1992S10blazer4.3
Jan 29, 2010 08:35 PM
