blower issues
Old Oct 20, 2010 | 12:09 PM
Crowbar's Avatar
Crowbar is on a distinguished road
Default blower issues
Hi to all,
Wow what a cool forum!
I have been lurking here and searching/reading lots, but can't find an answer to my issue so here goes....
1992 blazer with A/C - my blower motor died over the summer, man was it ever hot too!
With some help from here, I just replaced the motor. Now it works but only on the slowest speed. Its like the switch does nothing at all, no matter what position it's in I am only going slow. So, I am suspecting the switch. My question, how the heck do I get to the switch? Do I pry off that part of the dash, or are there screws I can't see. I just don't want to break it! I will probably replace both the relay and the switch, they are fairly cheap.
Thanks!
Old Oct 20, 2010 | 12:47 PM
mr.vls's Avatar
Two screws on the underside of the the switch panel and the plate will slide out the top. Check you resister pack that is bolted to the AC box. You could have an open resister.
Old Oct 21, 2010 | 06:45 AM
Crowbar's Avatar
Thanks!
I going to attempt to get that off today,
Not sure where you mean, the AC box, is that on the compressor unit under the hood?
Old Oct 21, 2010 | 11:06 AM
mr.vls's Avatar
The blower resistor pack is screwed into the evaporator housing under the hood. To the right of the blower motor. It will be the only elecrical plug that is on the evaporator housing. Two screws holds it in place.
Old Oct 21, 2010 | 04:38 PM
Crowbar's Avatar
Thank you sir, that was very helpful! unfortunately, the resistor pack was not the problem, but now I have a nice new one in place!
I belive I saw a post on here about testing the switch, I think I will try that next. I'm sure I will have more questions....
Old Nov 1, 2010 | 10:12 PM
STARMAN's Avatar
STARMAN is on a distinguished road
Im having a similar problem . Did you fix yours ? I could sure use any info .
Old Nov 3, 2010 | 02:28 PM
Crowbar's Avatar
Thumbs up
I sure did fix it!! After I replaced the motor and the resistor, I figured I would do the switch next. Once I pulled out the switch, I could see the burns and melting on it. New switch in place, and now low, medium 1, and high work. For some reason medium 2 goes at the same speed as low, but that's ok for me. Just in time for winter also!
I am sure you could test each part, but each part was under $20 to replace, so I figured what the heck. Good luck with yours, if you spend some time reading here, you can pick up TONS of good info, I know I have!
Old Nov 3, 2010 | 11:28 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Your Medium 2 problem is either the resistor (doubtful since it's new) or a wire connector. Check the LT BLU wire for voltage at the resistor when you have it in Med 2. You could have a bad connection at that connection if everything else works. This is from the factory wiring diagram. If you have voltage there, then check the DK BLU wire from the resistor to the relay. Troubleshoot backwards from there. It really should work since that''s the last resistor current runs through befire you kick it into HI (which is an entire different story). Sometimes the connectors go bad inside. You can jump around that problem.
maxvamp
Oct 31, 2020 08:19 AM
Jrbruno4208
Aug 23, 2011 06:01 PM
aztcwrior25otvws25
May 3, 2011 11:27 AM
jfrust64
Jan 5, 2011 07:12 PM
a_tack
Feb 17, 2010 04:44 PM
