Brake system failure
Old 12-05-2007, 10:52 AM
DetroitMuscle is an unknown quantity at this point
Default RE: Brake system failure
WHy was it running when you did the calipers?
Did you change out the rear brakes too?
Old 12-05-2007, 06:45 PM
thegr81's Avatar
I would check the calipers again make sure the slides are greased!! Then if it still does what its doing, then I would replace the proportioning valve!!
Old 12-05-2007, 11:25 PM
Hanr3's Avatar
Engine off
Pump peddle three or four times.
Push peddle to floor and hold.
Open bleeder screw, let bleed for 1-2 seconds, close screw.
Release brake pedal and repeat until all air is out of hte system.
Start with the furthest brake, passengers rear, then drivers rear, passengers front, and finish with drivers front. In that order. Make sure you dont run out of brake fluid, and put the cap on while bleeding. If oyu leave it off all your fluid will spill over thet top and it WILL suck air. 2-3pump/bleed cylces and you should need to top off. Your get the routine down ont eh frist brake.
Joey1986Z
01-23-2014 02:59 PM
teemac57
01-11-2014 05:11 PM
cricketkoger
06-13-2012 01:23 PM
cide
11-07-2009 01:26 PM
93LT
06-21-2006 07:38 AM
Quick Reply: Brake system failure
