car dies?
car dies?
Sometimes when I go to start the car I have to crank it for a good 5-7 seconds to get it to start which leads me to believe my fuel pump is bad. But if it was my fuel pump wouldn't it be acting up at idle or while going down the road? Because, my car only tries do die when I have to put on the brakes then make a sharp turn then to get it going again you have to push put the gas pedal about half way to the floor and crank it and hold your foot on the gas for a good 2 seconds or so to get it to stay running and it is normally fallowed by black smoke shooting out the exhaust.
sounds like you've got float problems in your carb.
how many miles? original carb, or has it ever been rebuilt?
Origional carb from the looks of it. Miles is unknown someone broke the odomoter at some point in time but I would assume quite high since it's a 84 and the average person drives somewhere around 12k a year so at most I would think 300,000 because it was sitting for a few years before I bought it.
Do you think the carb might just need adjusted or might just need a new carb?
Because I had the carb inspected about 4 months ago and the mechanic that took a look at it said it was set right. But I'm honestly clueless when it comes to carbs never worked on one or anything.
Origional carb from the looks of it......................
have you talked to the guy who looked @ it so many months ago?
it could be something as simple as a sticky needle, or it could be more serious like debris getting in side. the passageways inside the carb are so small, a grain of sand will inside it, would be like shoving a towel down your intake, chocking off the air/fuel supply.
while you're @ it, check and see what the actual fuel pressure is, @ idle, driving, and trying to mimic the situation where it occures. this will @ least give tyou some insight into what's going on with the fuel system, thereby helping to eliminate it, or highlight it.
Oh, ok thanks any idea what it might cost to rebuild a carb because O'rilies wants like $500 for a new one.
Or would something like carburetor cleaner maby take care of the problem?
live4liftin4848
01-02-2010 10:59 PM
Poligono
11-03-2008 06:01 PM
