check engine light
i just changed my plugs,distributor cap, rotor and coil and it went away so try doing or getting a tune up and see if it disappears
thanks man, you rock
lol np i try to help as much as I can since everyone else has helped me so much
any idea where I can get the codes for an 84 s-10 blazer? Troublecodes.net goes from 82-83 then right to 86. Also, can i use the paper clip method?
Yes, you can use the paper clip method.
When I describe these older computer vehicles as "archaic", I am describing the vague and ambiguous conclusions of the codes.
For example... if you get an oxygen sensor code, don't go changing the oxygen sensor... figure out what's causing the code to be thrown in the first place... like a rich running engine or a vacuum leak.
Alright. Thank you sir. I will check it out today.
Where is the 12 pin dlc located exactly? I located one on the passanger side but it only has 4 pins.
Under the driver side of the dash.
Thank you kindly.
Im trying the paperclip and get nothing to flash at all?!?!?! 93 s10 blazer
zombiewoof
02-01-2009 12:06 PM
zoniah
06-02-2008 08:45 AM
95_Blazer
12-06-2007 09:44 AM
Deezy
10-25-2007 08:58 PM
DBlaser_ca
08-02-2007 04:44 PM
