CODE 43, and 2 knock sensors?
Old May 10, 2010 | 07:15 PM
NC93BLAZERLT's Avatar
NC93BLAZERLT is an unknown quantity at this point
Default CODE 43, and 2 knock sensors?
My motor in the 93 isn't the original... It is a 4.3 Vortec W series. I need to know where the possibility of a second knock sensor may be? The one located between spark plugs on the driver's side is new. New plug too. I don't know where an additional (if that's the case) is located. Also, the book says something about a engine spark control module behind the block, but no diagrams... Is that the module in the distributor? If so, that's new too! My truck has an erratic idle. At first, code 43 showed itself at stop lights... But when I accelerated, it would disappear. Now it's constant, and idle problems... Any help? Thanks.
Old May 10, 2010 | 07:52 PM
ohsofly's Avatar
I beleive you have a knock sensor on the back down below the distributor too, I have never touched mine... But im sure I have read threads about them on here and there is 2 on the W engine. That code doesnt necessarily have to be a fault of the knock sensor or spark advance controler, loose rocker arms and torgue convertor bolts and anything loose and rattling can set the code 43 off too by sending a false knock sound through the engine. Ive never had it happen to me but I read alot online about these things.
Yes the spark module is in the bottom of the distributor.
Also, the W (CPI) engine IS the original engine for your 93. Its what most of us have. I think there is also a Z (TBI) engine, but not as many, and the W is much more powerful than the Z anyways.
Im sure one of our blazer gurus will chime in here soon on the info on your second knock sensor and some tests you can do.
Old May 10, 2010 | 08:06 PM
Back of the passenger side cylinder head.
Old May 11, 2010 | 07:00 AM
I did hear something about a flow chart to diagnose this code and problem step-by-step. Anyone else have this procedure(?)as it is not in the Haynes. @ OhSoFly: What I meant to say is that I believe this motor was swapped from a Camaro. Another thing: I wish there were some way to disable the ECU from adjusting timing upon receipt of a knock signal. Even if it's a little engine noise, it's affecting the way my truck runs by adjusting my timing automatically.
Old May 11, 2010 | 07:19 AM
Default Found the problem!
The 2nd knock sensor, which stood out like a sore thumb when I finally spotted it, is UNPLUGGED. The plug end is damaged. I'll go pick another one up today! Thanks guys.
holyman1973
Jan 27, 2013 12:50 PM
drin
Apr 26, 2010 02:10 PM
David Reeves
Dec 5, 2009 03:04 PM
transformer
Jul 3, 2009 11:44 PM
porta5
Mar 18, 2009 07:03 AM
