couple of probs
Old Nov 17, 2007 | 06:05 PM
sadmanco2004's Avatar
sadmanco2004 is an unknown quantity at this point
Default couple of probs
Alright, first off I love this site! I've had 3 blazers and this is the first site to go to when it comes to a question! So, with that said...... My dashlights are out on my 1993 Blazer and I can't seem to figure out where to start. It's an analog (non digital) cluster, and all of the gauges are not lighting. I've checked the circuit and fuse, but nothing! So, now it's all about how to get those bulbs changed............ Anyone done this?
Secondly, the guy that owned my blazer before me lowered it 3 inches. The rear end gives off a "whinning sound", and it isn't fading. I've had the truck 2 years (and has been making this sound since) and just never kinda want to tackle this, but it's got to be figured out. The pumpkin is full of lube and I added some not to long ago. It isn't leaking at all! So....... could this be a bearing or something?
~ S A D ~
-1993 Chevrolet S10 Blazer 4 door (rolling towards 250k miles)
Old Nov 17, 2007 | 06:44 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: couple of probs
ok this may sound su\illy but is the **** on the dashboard for the dimming of the lights turned all the way down????? and on the second thing maybe the u joints need to be replaced or mayve the rear is at the wrong pitch for the lowering Ive seen that personally so i know that can def happen!!!!!!!!!!
Old Nov 18, 2007 | 09:20 AM
Haha, no the dimmer isn't turned down. Done played with it, after changing fuses! How can you tell if the U joints are bad, before I try figuring out how to angle the rear end? Thanks for the early reply!
~ S A D ~
Old Nov 18, 2007 | 12:55 PM
2002XTREME's Avatar
u joints bad you`ll hear a clunk from them whe you put it in gear drive or reverse... As far as the angle of the rear i can try and find out the corect measurement for you on monday night, we rec had to adjust one in an s-10 that someone installed wrong when they bagged the truck...
Old Nov 18, 2007 | 04:08 PM
Cool, thanks for the help guys! There's a small clunk in the transmission when you shift from P to D, but I couldn't tell if it was the mount or maybe a u joint. Also, if I am just cruising through the neighborhood and stomp the gas you can hear it "clunk"........
Anyways, so no one's ever changed their bulbs in the analog dash before?
blazin97
Mar 26, 2006 03:01 AM
XBlazer01
Mar 11, 2006 02:45 AM
danny_walton2000
Nov 22, 2005 05:05 PM
jaybone420
Oct 15, 2005 03:04 PM
vmx120
Sep 12, 2005 07:10 PM
