Do i need valve seals or piston rings?
Old Feb 16, 2009 | 01:38 PM
lakeblazer91's Avatar
lakeblazer91 is an unknown quantity at this point
Default Do i need valve seals or piston rings?
91 4.3 TBI about a quart of oil every 200 miles, smokes white out pcv hole and dipstick tube, sooty black stuff coming out tailpipe, but not a lot of smoke out pipe. Im sick of wasting oil in this thing any idea whats causing the oil consumption. Thanks
Old Feb 16, 2009 | 02:54 PM
Default RE: Do i need valve seals or piston rings?
What do the plugs look like?
You could have either an oil ring problem or a valve seal problem. An exhaust valve seal issue will not show on the plugs as much as an intake seal issue would.
By far the easiest to deal with is the valve seals.
Old Feb 16, 2009 | 10:27 PM
Yeah plugs just changed and old ones where really white and corrode up almost plugging up entire gap.
Old Feb 16, 2009 | 10:39 PM
Really white does not sound like burning oil in the cylinders. They would normally be black.
Old Feb 18, 2009 | 10:06 AM
ok well i found a engine for 700 bucks so ill swap it out, using way too much oil for not leaking it on ground. Thanks hope the swap goes without a hitch for once
bertrenolds
Nov 7, 2012 03:05 PM
mierze
Apr 12, 2011 06:13 AM
llcooljeff26
Feb 20, 2011 09:34 AM
bigdaddykane93
Jan 16, 2011 01:58 AM
kerander
Feb 14, 2008 03:41 PM
