Electrical Problem
Old Oct 9, 2010 | 11:00 PM
amlarajr01's Avatar
amlarajr01 is on a distinguished road
Exclamation Electrical Problem
Ok I have a 92 blazer s-10 with a vortec 4.3. It is 4X4 with a vin w engine. Mechanicly wise i have brought this old beast up to speed almost. I am mechanicaly inclined but not electricaly if you know what i mean.
My problem started about 2-3 months ago when i would go to hit the blinkers. When i would hit them the wipers would come on for a second. Just recently the problem has gotten alot worse and fast. Now i have no gauges, no brake lights, no speedometer, and no blinkers at times.
I have checked all fuses and there good. Speedometer sensor has to be working because my transmission is shifting. Please help any advice would be appreciated.
Old Oct 10, 2010 | 06:57 AM
It sounds like you have some wires crossed up in the dash. I would start poking around under there.
Being that it is a '92, the VSS has nothing to do with your transmission. Your truck has a 4L60 (700R4) which is not computer controlled.
If this were a newer s-series (95+), I would say you have a problem with both your ignition switch and your multifunction switch, but I do not believe that the 1st gens suffer from the same ailments as the newer ones do.
JoSHN
Sep 14, 2012 04:56 PM
blazerxtreme1
Engine & Internal
Jul 7, 2006 12:46 PM
88s10Blazer
Jun 28, 2006 03:22 PM
Blazin99
Jun 12, 2006 01:15 PM
MontegoRX
Feb 15, 2006 11:30 PM
