Engine Stalling when trying to accellerate?
Hi Guys,
I have an 88 S10 Balazer with the 4.3 TBI 4x4. I have just installed a used low miles engine with all new stuff. It starts fine, a little high rpm for a minute, but then perfect. The issue is when I try to accellerate. The engine cuts out and stalls. It sounds like it has died but it is still running. It also does it in Park if you try to step on it and rev it up too fast. Can anyone tell me what to check first? Thanks.
RE: Engine Stalling when trying to accellerate?
I have the same EXACT issue... can anyone provide some insight?
Check fuel pressure?
First question for what reason did you change the motor??? did it do that b4? have you checked the timing? maybe theres a vacuum line off somewhere on the throttle body... just sum tips maybe they`ll help..makew sure you didnt crimp a fuel line putting the new motor in it.....
When you swapped motors did the exhaust take any beating during the job? ie: did you drop it down on the floor or shock it in any way? Check your catalitic converter, if it's broken up the little pieces can clump together by exhaust pressure and act like check valves...the back pressure from this will stall out the motor. I had the same symptoms and it was the CAT...it wasn't even broken up that bad, just a few pieces rattling around in it. The CAT is really fragile, I took my old one apart and you could crumble the pieces in your hand.
wcook369
12-21-2010 02:54 PM
PaulO2288
11-01-2010 06:10 PM
