Engine Tech Help Needed
Old Nov 8, 2004 | 08:14 PM
jp5162's Avatar
jp5162 is an unknown quantity at this point
Default Engine Tech Help Needed
94 Blazer 4.3 vortec
120,000 - well maintained
Fuel injection assembly has been replaced
Starts hard at times and has a rough idle - almost like the motor is skipping
New plugs and rotor, spark plug wires only a couple years old
Fuel filter and fuel pump has recently been replaced
?? possible oxygen or map sensor - not sure - any suggestions
Lost - please help!!!
Old Nov 25, 2004 | 05:37 AM
MeandMyChevy's Avatar
MeandMyChevy is an unknown quantity at this point
Default RE: Engine Tech Help Needed
Try running some "Sea Foam" motor cleaner through it, it come sin a white and red can, about 5 bucks. I just through a can of it in my tank to try and clean my injectors out. I havent read one bad thing or heard one bad thing about and I researche dit for like 2 hours. i go tmine at Auto Zone. Try it out and if you follow the directions then it will clean every bit of anything thats bad out of your engine. Heres a detailed intruction link. http://members.nuvox.net/~on.roz/cars/z28/seafoam.html
Old Nov 27, 2004 | 09:51 AM
jtroske's Avatar
jtroske is an unknown quantity at this point
IF YOU'RE RUNNING A VORTEC TRY CLEANING THE IAC OUT WITH CARB AND CHOKE CLEANER.IT MAY BE STICKING OPEN GIVING THE ENGINE TOO MUCH AIR AT IDLE
Gnfanatic
14
Jan 27, 2012 06:02 PM
bobbyb64
Sep 3, 2011 04:04 AM
lombard
Tires and Wheels
Aug 2, 2010 08:52 PM
swartlkk
Forum Notice
Dec 1, 2009 10:01 AM
blazer_geezer
Apr 27, 2007 01:55 AM
