Fuel filter
Old Mar 13, 2011 | 10:02 AM
rob180's Avatar
rob180 is on a distinguished road
Default Fuel filter
Did a tune-up on my 94 vortec, plugs cap wires air filter. Still have a little hesitation and sometimes rough idle at a stop light. Is the fuel filter pressurized on this year blazer? My old 87 tbi was, and my manual only covers upto 87. If it is how do I de-pressurize it so I don't take a bath in $3.65 cent a gallon cologne!! Thanks..........
Old Mar 13, 2011 | 10:50 AM
ffox's Avatar
ffox is on a distinguished road
Yep, it's pressurized. On the rear right side of the intake, where the fuel lines come in is the fitting to check fuel pressure, should have a screw on cap, take that off and press on the little valve core, just like letting air out of a tire.
Old Mar 13, 2011 | 11:12 AM
ohsofly's Avatar
Thats also where you want to screw your furl pressure gauge on and check for leaking off of pressure.
Old Mar 13, 2011 | 11:52 AM
rob180's Avatar
Outstanding!!!!!!!!!! Thanks alot guys, also good to know that thats where I check for leak off pressure. Should re-pressurise when I turn on the key when its all done then. Thanks alot again!!
Old Mar 13, 2011 | 05:11 PM
ohsofly's Avatar
Yeah just turn the key on and let it buzz up to pressure. It will return the air back to the tank through the return line. When the buzzing stops it should start like normal.
Try blowing through your new filter, and then blow out the old one... You will know if that was your problem or not if it feels like you are going to blow your ears out cause its plugged.
bigdaddykane93
Jun 25, 2012 01:24 AM
95jblaze
Aug 27, 2011 03:46 PM
brianroark
Jun 25, 2010 03:14 PM
Chalz
Dec 4, 2008 06:11 PM
riverjamie
Sep 24, 2007 08:21 PM
