Fuel pressure
Old Jan 5, 2009 | 01:32 PM
harpnicholas's Avatar
harpnicholas is an unknown quantity at this point
Default Fuel pressure
I have a 93 s10-blazer with a 4.3 that wont start and i was woundering if any one konws what the fuel pressure on that vehicle is suppose to be at key on engine off and key on engine crank
Old Jan 5, 2009 | 01:40 PM
Default RE: Fuel pressure
TBI or CPI?
Old Jan 5, 2009 | 01:42 PM
it is TBI
Old Jan 5, 2009 | 01:46 PM
I believe it is in the 8-10psi range. You will need an adapter to be able to test the fuel pressure at the TBI unit.
Old Jan 5, 2009 | 01:49 PM
ok them i was wrong it is the one with a main injector in the center of the intake
Old Jan 5, 2009 | 01:55 PM
Ok, for the CPI engine (the one with the plastic cover with the word "VORTEC" molded into it), the pressure should be 52-60psi for proper operation of the pressure actuated poppet nozzles. The fuel pressure test port is located off the back of the intake near the brake booster.
Old Jan 5, 2009 | 01:59 PM
so on crank ist should be 52 on crank or with key on engine off
Old Jan 5, 2009 | 02:17 PM
It should be at least 52 psi. It should never fall below 52psi which is near the minimum pressure required to open the poppet nozzles.
brianroark
Jun 25, 2010 03:14 PM
Spartan66
Jul 11, 2008 02:34 PM
riverjamie
Sep 24, 2007 08:21 PM
aspenpup
Sep 9, 2007 07:11 PM
jlinder
Aug 21, 2005 11:08 AM
