Fuel pump testing?
I have a '91 4 door T-10 4.3L
Want to test fuel pump amp draw, but do not have G pin in ALDLport to test pump.
Is there an easy way to run the pump, need more then 2 seconds.[sm=headbang.gif]
Pull the fuel pump relay and jump across the appropriate pins. The relay should show which pins are switched.
Thank you Kyle!
Started to suffer from brain fade, should have thought of that.
3D_Illustrator
08-12-2009 03:52 PM
