general question
look i found oil on my starter(not good) so i removed my torque comverter dust cover to check for oil,hard to tell so i noticed my oil cooler line was leaking from the block down the torque converter coverand on the floor.is there any way possible that the gasket on block that the oil cooler line connects to is shot,leaking in the torque converter cover on to the starter.is that possible or is the rear main seal.are there any other ways of checking the rear main seal for leaks.and if it is the rear mainis it worth replacing
Again, why do you insist on starting new threads when this clearly pertains to your thread on oil leaks.
LOCKED! Replies should be done here: leak
Or maybe could it be this one: vaule covers
How 'bout this one: oil cooler line
Maybe this one: rear main seal
No... : no oil
All replies will only be done to the thread entitled leak
All of these threads are off-shoots of the 'leak' thread.
No... : no oil
98Ltblazer
Apr 11, 2010 11:34 PM
cur dog
Jul 14, 2009 07:37 AM
