high idle
Old Oct 5, 2009 | 04:29 PM
4uzindian's Avatar
4uzindian is on a distinguished road
Default high idle
1988 blazer 2.8L engine . 22o TBI carburator. it idle's at 1100 rpm. new air cleaner gasket. could it be the TPS? any advice on how to lower it would be appreciated.
Old Oct 5, 2009 | 08:23 PM
Replace your throttle body base gasket. These are known to go bad. While you have the throttle body loose, clean it up.
Old Oct 6, 2009 | 02:09 PM
4uzindian's Avatar
thank's for answer. is that where carb attaches to manifold?
Old Oct 6, 2009 | 05:05 PM
Yes. Technically it is not a carb though.
Old Oct 7, 2009 | 02:19 PM
4uzindian's Avatar
thank's for answer. also can the ignition timing be adjusted on this engine or is it factory set. 2.8L - 220 TBI injector unit?
mcdevin1973
Oct 5, 2014 02:52 PM
midnightryder
Dec 29, 2009 02:43 PM
need new tires
Aug 7, 2006 04:05 AM
slicker
Feb 12, 2006 09:02 PM
IceFire
Dec 7, 2005 03:55 AM
