Hydrolock question
Hello I'm Dan and a new guy to the forum and have question I hope it is in the right place, I have an 84 first gen that i put a 94 5.7 TPI motor in,everything went great untill I tried to start it and it hydrolocked on me, #6 cylinder filled up with gas, luck was with me and it just blew the nosecone off my starter, but after putting in a new starter it still does it, I have put in new injectors and had a new harness made from chevythunder.com.What would cause this ? I pulled the vac line off the fuel pressure reglator and there was gas in the line and also my plenum,is the regulator bad or do I have it hooked to the wrong vac port? This being a batch fire system I would think all the cylinders on that side to be full since it fires all of one bank at a time, not just the number 6 cylinder. This is a speed density system with the 1227730 ecm, I have had it running for about an hour and it ran rich but after the hydrolock I had to change the starter and flexplate and oil and have not had it running since it locks up right away. sorry for the long post but I am lost here any help would be great. Thanks
TDawg
Jan 9, 2011 02:53 AM
98Ltblazer
Apr 11, 2010 11:34 PM
Numba1Sean
May 6, 2009 11:48 PM
redfan13
Mar 11, 2008 09:37 PM
Chadoo951
May 6, 2007 07:01 PM
