I need locks
Old Jul 22, 2005 | 10:35 AM
bomber 1's Avatar
bomber 1 is an unknown quantity at this point
Default I need locks
Hi i have an 88 blazer, and i need to find a lock set for it. i need both doors and the rear tailgate lock cylinders. Does anyone know where i can find them??
tahnks
Old Jul 22, 2005 | 01:18 PM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
Default RE: I need locks
A) Junkyard
B) Dealership
Those are the only places I can think of that would have a matching set. I know at work (AutoZone), we sell the door and rear key cylinders, but they wouldn't match. You'd have keys for the left, right, and rear.
Old Jul 25, 2005 | 01:28 PM
Hanr3's Avatar
Junk yard is your best bet.
I bought a '91 S10-Blazer for parts. One of the parts I took off of it was the door locks and rear tailgate lock. They come out pretty easy. There is a slide on clip inside the door that you need to remove and the lock comes out. Disconnect it from the lever (don't lose the connector). By far the hardest was the tailgate lock. That was because my tailgate was shut and I didn't have a key to open it. Took a bit, but I figured out how to get the trim piece off and then the lock. When you do pull the lock from the junk yard truck, take the rear gate inside trim piece. You might destroy the one in your truck trying to get it out.
There are 2 screws on each end at the top of the gate, plus screws below the floor trim piece, which you cannot get to becuase the door is closed. If your gate can open, no problems, however if it is closed.... get the junk yard rear gate trim piece just in case.
Old Aug 1, 2005 | 03:58 PM
blazinalpine's Avatar
blazinalpine is an unknown quantity at this point
i used locks out of 80some cutlass,left the adapters behind,use your current ones as they will fit
Old Aug 3, 2005 | 03:09 PM
TexasAxMan's Avatar
TexasAxMan is an unknown quantity at this point
Try www.classicindustries.com or www.yearone.com. They have almost everything for these trucks.
Old Aug 11, 2005 | 09:11 PM
bomber 1's Avatar
I got a pair at auto zone for 15 bucks and they even have matching keys.
Old Aug 12, 2005 | 05:48 PM
Yeah I forgot the door locks come in pairs with matching keys. My fault bro, didn't mean to be misleading.
BradensCreed
Aug 2, 2007 11:15 PM
Bojib
Jan 27, 2006 01:29 AM
Canadian88
Tires and Wheels
21
Dec 7, 2005 10:50 AM
Ricksastar
Apr 24, 2005 07:05 PM
BLAZINBlaZer98
Mar 1, 2005 10:53 PM
