Leaking brake fluid & coolant need help asap
Old Dec 24, 2011 | 08:31 AM
workshop4ever's Avatar
workshop4ever is an unknown quantity at this point
Just looked it up for curiosity.
Fuel Line Rated PSI: 30-90
Brake Line Rated PSI: Around 2,000 PSI
Old Dec 24, 2011 | 08:58 AM
01BlackBeauty's Avatar
01BlackBeauty is on a distinguished road
Although fittings and brake lines can develop leaks a more common cause of losing brake fluid would be a leaking brake caliper or wheel cylinder. I would check the calipers/wheel cylinders and/or backing plates for signs of leakage.
Have you checked the coolant level in the radiator? It may be low and drawing the coolant in that you are putting in the overflow reservoir. Otherwise, it may be a leak in the reservoir itself as previously mentioned.
Old Dec 24, 2011 | 12:28 PM
rriddle3's Avatar
If you have a coolant leak and cannot identify the source, have a coolant pressure test done to find it.
Old Dec 24, 2011 | 03:10 PM
89Recon's Avatar
89Recon is an unknown quantity at this point
I have it is perfectly fine so I am sure it is not that
also rriddle3 how much does a coolant pressure test cost? or is it something that can be done yourself?
Old Dec 24, 2011 | 05:43 PM
rriddle3's Avatar
Originally Posted by 89Recon
...also rriddle3 how much does a coolant pressure test cost? or is it something that can be done yourself?
You can buy the necessary equipment at an auto supply.
The thing to look out for with a coolant leak is the lower intake manifold gasket leaking as is well known for these engines due to the design of the OEM gasket. If that's it, it needs to be replaced with the Fel-Pro gasket kit. Leaking from the LIM gasket will ruin the bottom end of the engine due to oil contamination by the coolant.
Old Dec 24, 2011 | 07:02 PM
89Recon's Avatar
where is the lower intake manifold located ?
smg614
Jun 21, 2011 12:13 PM
eric_marchi
Mar 7, 2011 08:57 PM
ToughRod
Jan 13, 2011 04:36 PM
Skeeter Cruz
Mar 4, 2010 07:07 PM
