Missing vacuum hose connection
Old Apr 7, 2014 | 07:07 PM
btb1003's Avatar
btb1003 is on a distinguished road
Default Missing vacuum hose connection
1994 S0 Blazer 4x4 4.3 CPI... After changing the plugs I discovered a vac line broken from age that leads to somewhere near the firewall on the passenger side . It heads towards the front along the fenderwell and curves under the battery box to what I believe is a canister. Any ideas on where the broken end connects to? BTW, All hoses at the tee behind the intake are connected. Mileage has dropped to 14 mpg
Old Apr 8, 2014 | 11:32 AM
Skitzoape's Avatar
Skitzoape is on a distinguished road
If its going under the battery, thats where the 4wheel drive vacuum actuator is.
Old Apr 9, 2014 | 07:58 AM
btb1003's Avatar
Any idea where the opposite end connects?
Old Apr 9, 2014 | 08:28 AM
EZEARL's Avatar
EZEARL is on a distinguished road
If it's the one to the actuator the other end connects to the vacuum switch on the transfer case.
Old Apr 9, 2014 | 11:08 PM
TheRemedy's Avatar
TheRemedy is an unknown quantity at this point
If it's the 4wd line, it will follow the transmission dipstick down to the transfer case top. It can be a challenge to get to, but you should be able to trace it back from the switch by feel.
DeafTimberWolf
Jun 7, 2018 05:01 PM
chcknugget
Mar 4, 2013 06:45 AM
TimAH
Sep 14, 2011 04:26 PM
4thgenceli
Feb 27, 2011 02:07 PM
mohawks76
Performance & Brainstorming
May 24, 2008 09:42 PM
