Need help bad
Old Sep 14, 2009 | 12:43 AM
blazethis93's Avatar
blazethis93 is on a distinguished road
Default Need help bad
I got a 93 blazer and the four wheel drive wont work ive hooked up what vacuum ive found unhooked but i dont really know **** about four wheel drive so im lookin for someone around here that can check it out for me or can go into detail how to fix it. Im also lookin for a lift kit cow hood what ever you got get at me. I live in middletown ohio
Old Sep 14, 2009 | 06:35 AM
Sisk's Avatar
When you shift into 4x4, what happens? Do you hear it actually engaging?
And by a "cow hood" do you mean "cowl hood"? If so Just look around, there are a few people on here with them.
As for the lift, are you looking for a body lift, or suspension lift?
Old Sep 16, 2009 | 12:34 PM
old skool luvr's Avatar
you don't mention if your truck is manual engagement or electronic?
if it's manual, make sure the linkage is connected under the truck (between the shift lever and the transfer case). also, check that the vacuum diaphragm to engage the front diff is working (it's located under the battery tray). check it for the proper vacuum, if the cable is "pulling" the engagement in the diff far enough, and the hose for the vacuum feed of the diaphragm.
if it's electronic, it could be the switch in the dash, or the shift servo on the side of the transfer case, which can be quite expensive, so don't just by this if you think it might be the problem-be absolutely sure first (check for any shorts if you think this could be the problem).
Old Sep 21, 2009 | 09:41 AM
sorry i didnt go into detail but its electronic. if i put it in n and push the button both lights flash a couple times then both stay lit i can hear something in the passenger side floor click twice but theres still nothing but yes i ment cowl hood and wats better as far as a lift i found a 3'' body lift new on summit or zone site for $123 but now im havin problems with my lug luts stayin tight lol this things killin me but thanks for your help
Old Sep 21, 2009 | 10:38 AM
Sisk's Avatar
Originally Posted by blazethis93
...wats better as far as a lift ...
That really depends on what you're looking for. Body lifts tend to be cheaper and easier (less parts involved), but you can only go a max of 3". A suspension lift will give you another 6" on top of that, but they can be pretty expensive and involved as far as parts go.
If you're just looking for clearance or room to put bigger tires on, go with a body lift.
Generally (from what I've seen) people start with a body lift, and then go into the suspension lifts after.
Old Sep 23, 2009 | 07:16 AM
ya what im wanting to do is just lift it a little so i can get a set of black 22s on it with a meaty tire so i can still do a little for wheeling
Old Sep 23, 2009 | 04:21 PM
you know, you'll find a bigger selection of tires (with a little more sidewall) if you go with 20's instead of 22's. plus they're alot cheaper too.
Old Nov 1, 2010 | 10:52 PM
Sturg's Avatar
Sturg is on a distinguished road
welcome to the forum. I'm from ohio as well about 30 minutes from middletown actually.
Blazer98guy
Nov 14, 2013 10:34 PM
Ken_E
Sep 9, 2013 10:44 PM
spittybays
Nov 3, 2012 04:12 PM
mtz57
Aug 21, 2010 10:10 PM
yazan84
Mar 10, 2008 06:53 PM
