Need help: manual window crank removal
Old Jan 4, 2008 | 11:18 PM
Dog's Avatar
Dog
Dog is an unknown quantity at this point
Default Need help: manual window crank removal
Did a search to no avail. I have an '88 with the manual window cranks. I am trying to remove the inside door panel, and this crank is the only thing left in my way. There must be a trick, but I am at a loss. Any advice on how to remove? Thanks in advance.
Old Jan 5, 2008 | 12:00 AM
Blazin_Jason's Avatar
Default RE: Need help: manual window crank removal
There is a little clip that clips into a groove on the crank usually. There are tools available from most any local auto parts store that you use to remove the clip. If you want to try you can use a flatblade screwdriver or 2 to remove it. Just push down on the door panel and use a light and look for the clip. Once you see it puch that **** off.
Old Jan 5, 2008 | 12:33 AM
Chevy Lover's Avatar
This is the tool you need. It can be done without it, but this is the easiest way. Dont lose the clip when you push it off, they can fly.
[IMG]local://upfiles/2910/CDDEAB6200544C91B9C2DB4F08D238D8.jpg[/IMG]
Old Jan 5, 2008 | 08:06 AM
Dog's Avatar
Dog
Excellent - just the advice I needed. Thanks guys!
Old Jan 5, 2008 | 08:32 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
I got that tool sitting around for the past 15 years, one of the best $5 dollar investments Ive made. However, its trickier then just sticking that in and the handle coming off, line up the clip on the crank W/ the indents on the tool and give it a nice smack, but becareful those clips LOVE to fly.
Buddykitchen
Dec 10, 2016 06:37 PM
g_mike
Aug 22, 2010 02:46 PM
sjogrenzr2
Feb 12, 2009 06:32 PM
1stgen4x4
Sep 12, 2008 07:10 AM
MarkARos
May 2, 2008 09:35 PM
