New member, failed emissions high HC at idle.
Old Mar 21, 2011 | 07:00 PM
m5james's Avatar
m5james is an unknown quantity at this point
Default New member, failed emissions high HC at idle.
Hey, thanks for viewing my thread. As i said before I am a new member using my brother's login, I bought his 1990 s10 blazer 4.3 a couple of months ago. In an attempt to get the title transfered into my name I failed emissions. The HC (PPM) idle limit is 220, I failed with a 580. The spark plugs were changed out for the proper AC Delco last summer, and just a few months back the catalytic converter was replaced due to it rattling. Any suggestions on this would be much appreciated!
NOTE; I am not the most mechanically inclined person in the world, but I am slowly learning.
-Elliot
Old Mar 21, 2011 | 07:59 PM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
Search for how to egr and do some reading in the threads. Go to Jiffy Lube or one of those places and get a fuel system cleaner. (Jiffy Lube around here guarentees theres).
Also, google your proplem and read what others have done to correct the problem.
Old Mar 21, 2011 | 09:31 PM
rriddle3's Avatar
*Elliot, I have sent you a PM.*
m5james's Avatar
This is James. Ive tested the actuation of EGR valve by pressing it w/ a long screw driver at idle and it'd stumble pretty heavily. I've removed it once and cleaned it like 7yrs ago or s when it was still Elliots truck while i was having the engine swapped in my 740iL. I cleaned it back then because it has a terrible stumbling issue and was referred to clean the EGR, but in the end it turned out to be a slowly failing fuel pump. Before I gave the truck back to him, i was averaging 16-18mpg, even towing a trailer. He's averaging 12mpg, so clearly something failed recently.
dannyek7
Jun 4, 2010 07:53 PM
edkimdavey
Aug 8, 2009 07:57 PM
dyeraudio
Mar 7, 2009 07:15 PM
Spartan66
Jul 3, 2008 12:11 PM
Blahman20
Apr 21, 2007 07:06 AM
